terryb52 Posted July 10, 2004 Share Posted July 10, 2004 I currently have 205/60/15 on my '92 Legacy wagon. I went to one tire place and they said I should revert back to 195. What do you think? What is the reason for either size? Quote Link to comment Share on other sites More sharing options...
northguy Posted July 11, 2004 Share Posted July 11, 2004 The tire place, I'm sure, is going by what the book says since there have been places sued by litigous ***holes for putting on different sized tires than the specs call for after the *** holes got in a wreck. As long as all four tires are the same (and not too radically different so as to make the center of gravity way different) it should be fine. Quote Link to comment Share on other sites More sharing options...
Setright Posted July 11, 2004 Share Posted July 11, 2004 195/60R15 gives more predictable handling. 205 looks better, but since it's still 60 profile, you'll get more squashy steering, and more sudden break-away. Quote Link to comment Share on other sites More sharing options...
Warp3 Posted July 11, 2004 Share Posted July 11, 2004 If you don't mind the speedo/odo error (with the larger tires, your speedo reads slower than you are actually going by a small amount) and you aren't getting any tire rub from the extra width and height...then you are fine. As for the speedo error...you aren't too far off anyway, with your current difference from stock, when your speedo reads 60mph, you are actually going 61.2mph. Quote Link to comment Share on other sites More sharing options...
terryb52 Posted July 13, 2004 Author Share Posted July 13, 2004 I had no idea I was a speeder:grin: Quote Link to comment Share on other sites More sharing options...
