April 24, 20223 yr Hei folks, While doing some periodic maintenance and servicing, noted that the two rubber tubes coming up form th ePCV assembly are totally stiff and dry, would like to replace them red dots in pic well.... went to opposedforces but just can find the part number for it! closest i got was in the PCV diagram, but it has numbers for the two smaller pipes, not the assembly in the middle that i need! any idea where to find the pat number? Car is a european X2.0 2004 forester with EJ20 tnxs!
April 24, 20223 yr if there is no assembly number, then it is not sold as an assembly if there are no numbers at all, then it is very likely that those parts are no longer available Keep in mind, your car is 18 yrs old (mine is the same) - part supplies get depleted and are no longer manufactured for older cars
April 25, 20223 yr Author Indeed, it's not an assembly, but can get all the dry tubes looks like i was simply looking in the wrong area.... found http://opposedforces.com/parts/forester/en_s11/type_1/intake_and_supply_system_turbocharger/intake_manifold/illustration_5/ 18 years old is rather new in my book , certainly compared to my 1989 Vitara....
