brus brother Posted July 15, 2004 Share Posted July 15, 2004 90 Loyale. I get a brake squeal out of the front left wheel when braking but not when braking while in reverse. What gives? Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 15, 2004 Share Posted July 15, 2004 Pull the wheel off and find out Prolly just the indicator touching the rotor. That indicates your pads are low. Wont know tilll ya look Quote Link to comment Share on other sites More sharing options...
brus brother Posted July 15, 2004 Author Share Posted July 15, 2004 nope, the pads have about 3/4 meat left Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 15, 2004 Share Posted July 15, 2004 But was the indicator clip rubbing? Sometimes when pads get put on the indicator thingy doesnt get adjusted properly or at all. Then it squeals even tho there is plenty of pad left. Look on the disc itself for signs of metal on metal wear. Perhaps you mgiht see where its rubbing and determine the cuase. Grab and shake everything good. Rotor solid? Calipber on tight? Strut and kuckle seated firmly? Pads cliped in and not dragging on the rotor? Quote Link to comment Share on other sites More sharing options...
brus brother Posted July 16, 2004 Author Share Posted July 16, 2004 OK, so make it hard on me. I thought I could get a can of "Squeal No More" and pour it on the left front fender and ... tada! I'll follow your check list. Back to the original question, why doesn't it squeal when braking in reverse? Quote Link to comment Share on other sites More sharing options...
the_bard Posted July 16, 2004 Share Posted July 16, 2004 ... can of "Squeal No More" ... When you find a can of that, lemme know, ok? Hope they make "Rust No More", too. Preferably in an aerosol can Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 16, 2004 Share Posted July 16, 2004 Back to the original question, why doesn't it squeal when braking in reverse? That's what first led me to think the little indicator tab. !_! Quote Link to comment Share on other sites More sharing options...
