pulling crank and cam sprockets?
That type of puller is used for pulling the crank and cam sprockets? I want to replace the seals but not sure how to get them off Sorry for all the dumb questions but, I bought two manuals online and have not recieved them yet. Thanks David C
The cam gears are simple as pie. THere are just 3 bolts holding each one on. There is some fancy tool that holds the gear while you tighten/loosen the bolts. I just break them loose while the belts are still on.
Crank gears are mostly held on by the pulley and main crank bolt. THere is also a key hodling them on. Youll notice the gears are sloted and there is a little metal key in there. Sorry it's been so long since I had to pull those off i cant think of any tricks :) Just hack it !_!
Shouldnt need any special puller or tools. GOod luck!
