July 18, 200421 yr My timing belt/seals/water pump project has gone well with the help of this board, but now I am stuck again. When I pulled the thing apart I found a 2 inch piece of 25mm rubber hose stuck between the water pump and the water intake tube, now I see why. The old water pump had a bunch of pea size gouges in the walls of the port the intake tube fits into, OK so I am thinking there was trouble getting the tube out or what I don't know. On reassambly I find that the tube just bearly touches the inside of the port when the mounting bolt is installed. I don't want to repeat the performance of the mechs that worked before me so I guess I need a new tube. Can anyone tell me where I can find a good intake tube.
July 18, 200421 yr Author No Subarus in junk yards here in the land of Buicks, and Crown Victorias, That Sucks If I can find out where to get one online I would buy it today as my car is parked untill I get one. thanks
July 18, 200421 yr make a post at the marketplace, prolly the best way. all of the ones i have are bolted to cars =]
