July 25, 200421 yr Hello need help from the experts. Speaking more on the behalf of my mechanic than me, as I don't do A/C work. 1990 Legacy LS NA auto. 85K miles. New reciever/dryer, new compressor, new condenser, oil, o rings, fittings, etc. Correctly converted to r134a as double checked per these instructions: http://pub205.ezboard.com/fultimatesubarumessageboardsfrm6.showMessage?topicID=110.topic Anyhow, it doesn't work. Blows warm. Couldn't find any leaks, system was vaccuumed correctly etc... Are there any tricks? Quirks? Any other fittings that are prone to failure during the retrofit that we may be unaware of? Something specific to the 90-94 Legacies? Thanks, Loomis
July 25, 200421 yr Did it work before the conversion at all? Sounds like you've replaced a lot of stuff. Could be evap core, expansion valve, or possibly temp sensors related to the ac system.
July 26, 200421 yr Does the compressor cycle on at all? I'm sure he's done this, but double check the pressure. If it is too low, or too high the compressor clutch won't activate.
July 26, 200421 yr Anyhow, it doesn't work. Blows warm. Warm or Hot? If the engine is up to temperature does it blow warm or hot? You could have a situation where the the flapper that controls whether the air flows over the heater core or not it no longer being moved and is in fact stuck half open/closed, therefor heating the air being cooled by the AC and making it feel warm. Keith
July 26, 200421 yr Thanks for all the tips guys. Let me print this thread out and take it to my mechanic and see what he says. Will post reply later this week. Thanks everyone! Loomis
July 28, 200421 yr need more info as to what is not happening. clutch on? if so what are the pressures? but the big question for me is why did you change it over? r12 is better and still very available. george Hello need help from the experts. Speaking more on the behalf of my mechanic than me, as I don't do A/C work. 1990 Legacy LS NA auto. 85K miles. New reciever/dryer, new compressor, new condenser, oil, o rings, fittings, etc. Correctly converted to r134a as double checked per these instructions: http://pub205.ezboard.com/fultimatesubarumessageboardsfrm6.showMessage?topicID=110.topic Anyhow, it doesn't work. Blows warm. Couldn't find any leaks, system was vaccuumed correctly etc... Are there any tricks? Quirks? Any other fittings that are prone to failure during the retrofit that we may be unaware of? Something specific to the 90-94 Legacies? Thanks, Loomis
