March 3, 20242 yr Good afternoon! I've found the rodent damaged wires, it's on the four-wire plug leading into the passenger side fuel injector port. I'm guessing it's the fuel pressure sensor. The rodent not only chewed through the wires but it took off with a three inch strand. I'm looking at needing to splice in a replacement wire. I have no clue what gauge wire will be needed for the splice. It's stranded wire. I've attached a picture below - any knowledge on this wire gauge? Thanks in advance
March 4, 20242 yr I'm only guessing 18 gauge. Take wire to HD or Lowes and compare size with wire stripper?
March 4, 20242 yr https://wetechnologies.com/technical-info/Stranded Wire Chart.pdf Compare your wire to fractional small drill bits to gauge the wire, if you don't have inch calipers.
