Greentractorfarmer Posted July 13 Share Posted July 13 Hi All, I’ve been learning from this wonderful site for half-dozen years, so let me start my first post with a hand-clapping thanks to the many people who’ve helped me along. I bought an ‘83 GL new, kept it all these years, and in 2021, swapped in a 2000 Impreza 2.2, California spec. My fun with that wagon ended with a roll-over, last year. I’m lucky to have found a running Brat (1985) and began pulling over the parts from the wagon, which included the 15” wheels and 2.2 fuel injected engine, wiring harness, and pretty much all the interior fittings. Now to the point of this post. I am unable to make the engine run in the Brat as it did in the wagon. The engine starts, idles smoothly, and can have full power. But intermittently. The stutter/cut-out is throughout the whole range of throttle, and depending on the rpm, can best be called ‘bucking’. The fuel system in the donor car had an in-tank pump with sensors for fuel level, pressure, temperature, and control valves for drain and purge (not the purge valve at the fuel rail). None of the sensors and valves came over to the Old Gen cars, although I did preserve the sensor wires to the area of the ECU. I ran a 5/16” line from an external Ford fuel pump to supply the engine, and used the original 1/4” supply as a return, and the 3/16” as a vapor line from engine to tank. That worked fine on the wagon, but I suspect the current problem is related to this set-up. I’ve replaced a lot of the sensors: front O2 at the exhaust, knock, throttle position, engine block temp, crank sensor, and tested the purge control valve to be operational with voltage, also the ECU with another. Also new plugs when moving the engine to the Brat, and then a new coil. The plug wires were new 5,000 miles ago, so don’t think the problem is in the ignition. I realize this is a vague description of what is in place right now, and hope someone will be interested and start a conversation to help with the next step. I’m wondering if anyone has opinion/experience with the Cali-spec engine and whether my wiring loom can support an older (Gen1) intake and its ECU. I’m feeling pretty desperate and leaning toward finding a mechanic willing to work on this swapped set-up, with the thought that a more sophisticated diagnosing kit could narrow down the issue, whether the ignition or fuel is quitting. I’m working with a simple OBD reader, multimeter, pin-out chart for the ECU, and a 72- year old brain. It’s tough. Thanks for your time. Link to comment Share on other sites More sharing options...
bushytails Posted July 13 Share Posted July 13 I'm having a hard time understanding your post. You're using the same engine and harness and ecu that you used in the rolled car, in the new car, but now it bucks? Or this is an entirely new swap? If it's all the same parts that worked before, it's obviously not incompatibilities between them or what the wiring harness supports. Or did you mismatch intakes when you originally built? Again, if it worked before, not the problem now. Since you're suspicious of the fuel supply, start with a mechanical fuel pressure gauge. Extend the hose long enough to route out through the edge of the hood and tuck under your windshield wiper. Take it for a test drive. Fuel pressure should be solid, and should go up 12 psi when you go from idle to full throttle. Does it buck at idle, or only above a certain amount of engine load? On your obdii scanner, use the live data mode (if it doesn't have live data, bin it and spend $50 on a new one), looking for any sensors that move in a sudden fashion, especially if it correlates with the bucking. If it's a fuel injection issue, an oscilloscope is really handy... Here's a couple pics from last time I was troubleshooting a bucking issue: https://imgur.com/a/RwWTdwG In these images, the jumpy green trace confirmed the bad component - MAF sensor. Link to comment Share on other sites More sharing options...
Greentractorfarmer Posted July 13 Author Share Posted July 13 Correct, the engine and wiring from the first GL swap are installed in the current Brat GL. I have a fuel pressure gauge, downstream of the filter, rigged just as you describe so it can be read when driving. 38-40 psi at idle, high 40’s when throttle opens, and holds when shut down. Actually the pressure slowly rises from 38 to 45 at engine off, holds at there for a hour, then slowly falls to zero over several hours. I think the pressure increase at engine off is heat expansion and assume the injector system is okay since it holds awhile before decreasing. The tank always pressurizes quite a bit, to the point that gas vapor smell is obvious, probably through the gas cap vent. This seems to be the only difference in the first GL with this engine and the current Brat GL-buckeroo. Your statement about the oscilloscope is helpful. It’s what I’ve been thinking is next step. (This particular model 2.2 didn’t use MAF, instead has manifold pressure sensor plus intake air temperature sensor.) I will need to get a shop to do this, but am concerned the Frankenstein aspect might add difficulty to getting that help. I’ve tried to use live data on my reader, but don’t get far. I also have back-probed at the ECU to read voltages of various sensor signal while driving, all looks solid. But the scope can show oscillations, while the meter only shows steady 12v at the injectors, for example. Thank you for the input. It’s encouraging. Link to comment Share on other sites More sharing options...
bushytails Posted July 13 Share Posted July 13 It's really hard to diagnose something like that without the "feel" of what it's doing that a test drive gives... Does it idle well, or does the problem happen at idle too? Link to comment Share on other sites More sharing options...
Greentractorfarmer Posted July 14 Author Share Posted July 14 Starts and idles just right. (Am I right that the idle circuit uses less info from sensors/ECU?) The first gear shows gentle surge pulses, and in second gear, between 1700 and 2500 rpm, the rougher ‘cut out’ happens pretty consistently. If I’m driving at low speeds 1rst and 2nd gears, I can get it to even out, but when running on the open road at 40 mph and faster, the throttle pedal has to be feathered to avoid pretty violent on - off power cycles that are split second in length: bucking. Temperature doesn’t seem to affect this problem. Engine load (uphill grade) might make it worse, but that’s not definitive. The TPS was always suspect, but tested fine for voltage and resistance, so I didn’t change that immediately, and several days ago when I replaced it, no difference. Link to comment Share on other sites More sharing options...
el_freddo Posted July 19 Share Posted July 19 Did you use the Brat’s fuel tank or bring the one over from the wagon? If using the Brat’s fuel tank I reckon it’s getting clogged up as you drive, fuel starvation then occurs as the pump struggles to get fuel to supply the engine under load. This doesn’t match what you said about your fuel pressure readings though. Is the ignitions switch on the Brat good? These can sometimes cause intermittent issues but seem more likely to die outright rather than a slow, twitchy death. Maybe list the things that are similar/same between the two vehicles that were swapped and not swapped. Something might show up there. Eg: - fuel lines - fuel tank - body harness - EJ power “pick up” points - where? Changed/same? Cheers Bennie Link to comment Share on other sites More sharing options...
Greentractorfarmer Posted July 22 Author Share Posted July 22 Very solid points, Bennie. Did not bring over the fuel tank from the wagon. I do suspect fuel to be at least part of the problem. My first effort was to install a pressure gauge. Also, the surging seems quite rhythmic when it occurs. I brought over the steering column from the wagon, including the ignition switch. I’m using the GL starting circuit on the Brat, as I had on the wagon. The trouble code of ‘starter circuit high’ is the same as it was in wagon. Also brought small fuse block that I’d used on the wagon, protection for the power to ECU. Using the same external fuel pump, and the relays from the donor 2.2. One surprise was that the fuel pump relay worked for a short time in the Brat and then quit. I replaced the relay and it’s been okay. The body harnesses are original to each body, only the engine/ecu harness came with the engine from the wagon to the Brat. The pump is mounted close to the tank, to which I’d added a filter when in the wagon, which didn’t get changed when brought over, had about 5,000 miles on it then. Maybe I should take a harder look at the idea of crud in tank. I’ve also brought the original fuel filter along with the engine, so the set-up has two. The pressure gauge is downstream of both, and does seem solid. The tank pressure and fumes are greater in the Brat than wagon, and I can’t figure why.I’ve tried running without gas cap, and with lines to the fuel separator box disconnected but that doesn’t affect the engine cut-out. Full disclosure, I let the wagon body go before finishing the install to the Brat, a mistake because when plumbing the fuel lines I think there is an additional port on the Brat fuel tank. I just added another tee in the original way I had plumbed the wagon, on the return side. Anybody familiar with the differences in tank ports between ‘83 gl wagon and ‘85 Brat? Best way to check the fuel tank? At the filters? More effort into the pressure gauge? Thanks Link to comment Share on other sites More sharing options...
el_freddo Posted July 24 Share Posted July 24 Over pressurisation of the fuel tank could be a blocked carbon canister up front if not using one from the wagon. Surging could be a little diaphragm device missing from the fuel system between the fuel pump and the engine. But if fuel pressures are solid and they don’t move this one doesn’t make much sense to me. To check the tank you can drain it via the bolt in the bottom of it, then remove the fuel sender unit at the rear of the tank to inspect the internals - use your phone camera to look through the hole and snap some pics with the flash. You’ll get a good idea of what’s going on in there with those pics, and you’ll have a reference point to start with if you need to do anything about it. I didn’t know about the fuel tank port differences. That T piece could be the issue that’s upsetting something. I wonder if you’re getting air in the fuel system that’s then making its way to the injectors at load, but at idle and low load revs the air manages to pass by without issue. I am clasping at straws here and thinking outside the box and hopefully helping out in the process. Cheers Bennie Link to comment Share on other sites More sharing options...
Greentractorfarmer Posted Tuesday at 04:53 PM Author Share Posted Tuesday at 04:53 PM Great info on the tank inspection, I’m moving the car to an independent mechanic today and will get some oscilloscope readings. I’m hoping to narrow the possibilities to fuel or spark with that help. I’m not using a charcoal canister but am thinking it would be a good thing to try for the vapor smell, unless something else improves the excess fumes when the engine problem is solved. I’ve used the stock 1983-85 fuel separator and piping in both cars (wagon and current brat), which includes the long switchbacking 1/8” pipe that has the diaphragm looking thing you mention. Lightening took out our solar electrics and radio, phone, internet, irrigation controls last week. I hope to get pressure back onto the Suby soon. I appreciate the brain work on everyone’s part meantime. It’s always better for the forum if one gets the final resolution to the story, so I’ll update asap. I keep circling back to the missing in-tank sensors (didn’t have them in the wagon and not in the brat now either) and my thinking is the purge valve on the engine should be helping to reduce vapor pressure in the intake system. The purge in my engine operates mechanically, tests properly electrically, but when I ground it (opens the valve), engine immediately stalls. Then I get kinda stuck trying to figure if the valve ever operates (or if it ever operated when engine was running properly in the wagon body). And how the ecu might be pulsing the ground connection for the purge valve, getting confused with the resulting signals from other sensors, and setting up the on/off that makes car buck. Link to comment Share on other sites More sharing options...
bushytails Posted Tuesday at 06:52 PM Share Posted Tuesday at 06:52 PM Does the bucking go away if you leave the valve unplugged? Link to comment Share on other sites More sharing options...
Greentractorfarmer Posted yesterday at 04:13 AM Author Share Posted yesterday at 04:13 AM No, the problem continues when the purge valve is disconnected. I got the car to a mechanic yesterday, and after reviewing the data with his scanner, and doing some research, he thinks the knock signal may be too sensitive. If the knock is sending a false signal to the ECM, it will pull the timing 10 degrees. I had also seen with my reader, with the live data, that the timing would advance 10 or more degrees when throttled up, but considered it normal, and couldn’t see that it corresponded with the misbehavior of the engine. Anyway, he says the service bulletin says to replace the ECM with an updated one and that people in the forums have been placing a resistor before the knock sensor. Anyone heard of this treatment? Or does it sound reasonable? Link to comment Share on other sites More sharing options...
bushytails Posted yesterday at 02:15 PM Share Posted yesterday at 02:15 PM Same question, different sensor. Does the bucking go away if you unplug the knock sensor? Link to comment Share on other sites More sharing options...
