shattered sunroof.... ouch!
Well, out the blue my GF's 1st series Forester cracked the sunroof
Nothing hit it, but now im reading that this simply happens sometimes
luckily looks like replacement work should be easy, but trouble is finding a used one (not about to pay 600-700 for new)
any idea if glass from SG, SH fits too? seems easier to find used
P/N are different, but that could be just shade color etc....
Tnxs
Edited by turboguzzi
It's not a hard job, but very labor intensive.
- Remove all the interior trim around the windows to drop the headliner.  Do it when it's warm and there is less chance of the plastic pins breaking.
- Remove the headliner, drop the seats so you have the most room to turn it and get it out the rear hatch without bend it too much
- Disconnect the sunroof wiring and drain tubes
- Unbolt the sunroof, 2 helpers make it easier.
- Reverse to install the used one.
If you have access to self-serve yards, you can practice on a yard car.
I know some of the slide hardware changed from year to year.  If you change the complete frame that issue goes away.  Best of luck!
  • Like 1
