Need an injector pump
scooby2
Is this a Carb/SPFI/MPFI/Turbo? The different fuel delivery systems use different fuel pumps. (I'm assuming you're talking about a fuel pump, if not then snap a picture of what you're talking about.)
If you let us know what it is I can get you a part number to cross-reference online listings.
I'm also going to see a parts guy in a few weeks, so I may be able to grab you what you need while I'm there. No promises but it's possible he'll have a spare.
Edited by SuspiciousPizza
Unless you've had an engine swap to something uncommon, the fuel pump is what pressurizes the injectors.  The injectors are electronically controlled valves, that let out a precise amount of fuel when the computer tells them to open and close.  The fuel to them is supplied, at pressure, by the fuel pump.  The only common exceptions to this are diesels, ancient satanic bosch fuel injection, and ultra-modern direct injection gas engines...
