LaMamelle Posted August 31 Share Posted August 31 Howdy! I just got my hands on a new (to me, not to the world) 1986 XT Turbo, that's been sitting in the previous owner's driveway since at least 2009. It has less than 100k miles, no accident history, and very little rust, or at least, not enough rust to make any holes. The reason it was sitting was because the ECU was fried. To what extent I do not know, all I know that he plugged in a wire and then realized it shouldn't be there, and there was no power. It looks like there is a fair bit of custom wiring that I am still in the process of investigating. I was able to get my hands on a replacement ECU, and I'm just waiting for it to arrive. However, there are some things that make me wonder if the issue could be deeper. There are some electrical systems work, but others that don't that I would expect to work. For example, brake lights and highlights work, but not the hazards, or turn signals. And I expected the radio and digi-dash to at least come up with light, but there's nothing. Looking at some wiring diagrams I think (If I'm reading it right) some of these systems should work without the ECU, but I could be wrong? I already plan to replace all the relays I can reach, and check every fuse, I assume that's a good place to start. Does anyone have any suggestions for where I should look out for? Thanks in advance! Link to comment Share on other sites More sharing options...
LaMamelle Posted August 31 Author Share Posted August 31 Just a quick update to this: I have gotten hazards to come back to life just by flipping the twitch about a million times, slowly beginning to wonder if the issue lies somewhere other than the ECU. The 1988 manual says that most body electronics go through the fusible links and ignition. I've double checked the links and they are all clean and they don't seem to be damaged in any way. So I'll try to diagnose the ignition switch next. Link to comment Share on other sites More sharing options...
LaMamelle Posted September 1 Author Share Posted September 1 Update: There didn't seem to be any voltage at the ignition switch, so I switched it out with the one on my 89 XT, and I now have radio! But no still no dash lights :(. But this does seem to lead me down the path that the issue may lie elsewhere, and not at the ECU. If anyone knows to what extent the dash would communicate with the ECU (or the MPFI Controller as the manual calls it), lemme know. But I'll keep digging. I hope that one day I will see that magnificent digi-dash. Link to comment Share on other sites More sharing options...
el_freddo Posted September 1 Share Posted September 1 I don’t think the EA82 era ECUs were integrated into the dash anymore than having a check engine light and referencing a reed switch on the speedo cable for the VSS. Do some research into issues with the digi dash, the EA81 MY’s digi dash was known for issues with some of the components dying, taking out the dash with it. You could have a similar issue in the EA82 digi dash. Cheers Bennie Link to comment Share on other sites More sharing options...
LaMamelle Posted September 1 Author Share Posted September 1 Thanks for the tip, I'll take out the dash and check it out. Something I should probably do anyways; I don't put a lot of faith in 80s circuitry. And I think that confirms for me that the issue is the ignition switch. I'll replace it and update on my success for failure. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted September 1 Share Posted September 1 I'd investigate your relays for your lighting issues. Getting stuff to work after repeatedly flipping the switch sounds to me like a relay issue. Look into service manuals online, or better yet buy a set of hardcopies. Well worth the investment and will tell you all you want to know and more. I believe the wiring should be the same as any 3rd gen/L-Series/Leone with a turbo MPFI engine. An XT is basically an L-Series with a cooler body and interior. I could be wrong though, I've never been fortunate enough to work on one nor see one in the flesh. Check everything that goes into the ECU before you plug it in. Takes time but with the car's age it's better to begin checking stuff now. :] Link to comment Share on other sites More sharing options...
LaMamelle Posted September 2 Author Share Posted September 2 It's Alive! After replacing the ignition switch, there is life! The engine cranks and even sputters with starter fluid! Digi-dash is also working thankfully, and seems to be reporting all the correct stuff. Turns out the ECU wasn't the issue, or at least it doesn't seem like it at the moment. I will be replacing all the relays for sure, since the blinkers are still a little funky (as in not working at all), and I can't hear the fuel pump come on. I'm sure since it's been sitting for a bit that doesn't help things. I did drain and flush the tank, so the next step is a real start! I was able to find a copy of the 88-service manual online, which I wish I had read before because it clearly states that all the dash stuff goes through the ignition module. I will see if I can find a copy on ebay or something. Link to comment Share on other sites More sharing options...
el_freddo Posted September 2 Share Posted September 2 The ECU will be under the rear parcel shelf in the Vortex from memory. Glad it was an easy fix. You’ll probably find your fuel pump will need to be replaced, I’d be doing it anyway. The relay is probably fine, it’ll be the pump that’s seized. You can easily test this at the plug for the pump, stick a test light on it and turn the key to the on position. It should illuminate for three or four seconds when the ECU triggers the fuel pump relay to prime the fuel system before starting. All the best with it. Sounds like you’re well on your way with this one! Cheers Bennie Link to comment Share on other sites More sharing options...
LaMamelle Posted September 5 Author Share Posted September 5 Thanks for your help and wisdom! Yeah, from what I read online, my next step should be to drop the gas tank and clean out the 16-year-old gas and varnish, which I have been dreading doing, but it's gotta be done. Once I do that, I have an extra pump lying around that I was saving for my wagon, I'll swap it in and see if I can start it up! From what I can tell the two pumps seem to be the same. Link to comment Share on other sites More sharing options...
el_freddo Posted September 6 Share Posted September 6 If you wanted to test the pump you could re-route the fuel lines so the pump is sucking from a Jerrycan and the return line is sent back to another container to push out any other crap that’s still in the fuel system. Just remember that the jerrycan will empty pretty quickly! Cheers Bennie Link to comment Share on other sites More sharing options...
