November 12, 2025Nov 12 A friend of mine is getting two codes on a 2012 Tribeca Tans codes P0710 and P0700. They will clear but come back in a month or so. Clunk and then the codes show up, otherwise drives fine. What do you think?
January 5Jan 5 Make sure the pan isn't dented underneath and ATF filter isn't nearly 20 years old and stuffed? Do a drain and fill and see what comes out of the pan? Was it a 1710 code or 0710 code? 0710 isn't showing in the 06 Tribeca FSM I have, they go from 0705 to 0712, maybe 2008 is different. Here's what the FSM has for P1710: P1710 TORQUE CONVERTER TURBINE 2 SPEED SIGNAL CIRCUIT 2 MALFUNCTION
