September 17, 200421 yr So I'm rebuilding a turbo at work. changing heads and all the seals. When I pulled the flywheel off I didnt mark where it was to the crankshaft. So to make sure I get it back on right (so the timing marks are lined up right) what do I have to do? The 3 marks on the flywheel (used for putting on the t-belts) the center line is for 1st cylinder TDC correct? So then if the center line is at the top mark on the bell housing and 1st cylinder it TDC everything will work right for when I time the engine correct?
September 17, 200421 yr Well lemme just be the first to say that the flywheel only goes on ONE way. You just have to lay the flywheel on the crank, turn it until all of the bolt holes line up and then bolt it in. Just a heads up:D
September 17, 200421 yr Author oh ok. well that pretty much answers my question. I didnt want to put it back together until I made sure Thanks for the help
September 17, 200421 yr As far as the three marks (why there are three is a mystery to me), those DON'T indicate TDC on #1. That's indicated by the degreed portion that you set the ignition timing from. I honestly don't know why those marks are where they are. Why didn't they just time it at TDC and adjust the marks on the cams accordingly? If anybody knows, I would love to learn why. If you've got any more questions, don't be afraid to ask. I may have some for you when I tear down my turbo motor at Christmas break.
