September 23, 200421 yr On my 87 gl Wagon I've got 185/70/r13s in the front and 185/80/r13s in the back because I found them cheap at a junkyard. I tried to put it in 4WD and it went crazy (obviously). I had to struggle to get it back in FWD. I have an axle going bad and I was just gonna remove it and have it be rear wheel drive but I dont know if that would work. Would it bind up like it did before or will it work fine in rear wheel drive?
September 23, 200421 yr it will work because the front diff can now rotate to relieve the difference in speed. Just remember to keep the front *outer* cup/stub in the hub so you can drive without the axle.
October 5, 200421 yr ya knock that outer cup off with a hammer, and clean the greas out of it... take out the bearings, and cage ifyou can, its kinda cool how it fits together =] you can remove one or both, i noticed no difference either way. try not to do too many brake stands with the e brake, as your tires will not last long
October 5, 200421 yr you can remove one or both, i noticed no difference either way. try not to do too many brake stands with the e brake, as your tires will not last long yeah I found that one out the hard way....brand new tires + rear wheel drive = no tires left:brow:
October 6, 200421 yr yeah I found that one out the hard way....brand new tires + rear wheel drive = no tires left:brow: Set the parking brake, Rev to a decently high RPM, drop the clutch, and flip the fan switch.. Boy is it fun with an LSD, Two-Tire Fire anyone? Smoke-O-Rama
