October 7, 200421 yr !!!!!!!!!!!URGENT!!!!!!!!!! Hey yall, Have a question for you...i am putting a new(used) transmission in my 1997 impreza sedan... i have a lead on a new one but i need to make sure they mate and the drive ratios for the diffs, match up. so i have a few questions 1. What is the final drive ratio for my diffs in my 1997 Impreza L Sedan? 2. What is the final drive ratio for a 1999 Legacy (Transmissino pulled from) 3. Will this transmission from 1999 legacy mate to my ej22 Here is the email from the person selling it "It will fit any EJ20 engine, I don't know what the final gear ratio is. It was stored with trans fluid in it and is in perfect shape. I'm selling it because I only needed the engine for my sandrail project, and when i bought the engine I had to by thewhole drive train. Jon" Basically...will it fit and work...any help is extremely appreciated thanks Cory
October 8, 200421 yr !!!!!!!!!!!URGENT!!!!!!!!!! Hey yall, Have a question for you...i am putting a new(used) transmission in my 1997 impreza sedan... i have a lead on a new one but i need to make sure they mate and the drive ratios for the diffs, match up. so i have a few questions 1. What is the final drive ratio for my diffs in my 1997 Impreza L Sedan? 2. What is the final drive ratio for a 1999 Legacy (Transmissino pulled from) Cory I will take a stab at 1 and 2. Why do you care? As long as the front rear diffs are the same the tranny is not important.
October 8, 200421 yr I wonder if there is a ratio tag on it like the rear end would have. Can you check the tag on the rear of the car it was pulled from? Or is that car elsewhere?
