Got a dual range coming! questions...
I got an OK deal on a dual range 5 speed tranny out of an '86 wagon non turbo car with a carb. I even got the correct color interior peices to go with. I pick it up in two days and still have a few questions after searching...
Do I need to pull the engine at the same time or can I sneak everything out from behind it?
Also, my car is a Turbo car (push button) and the doner is not. Am I going to need to grab the front axles and the rear diff at the same time?
Thanks.
yes you can drop the tranny out the bottom of the car. and you need to check to see if the rear diff in the donor car is a 3.9 or 3.7. if it is a 3.9 you need to get that also cuz yours is a 3.7 cv can't say for sure
Thanks! I'll get them also. Looks like I'll be giving $235 for everything that it will take (axles, rear housing, misc.)
I might start tearing into it this weekend. :D
