edjackie88 Posted October 18, 2004 Share Posted October 18, 2004 How do I pull abs codes on a 98 legacy outback wagon. It appears to have the 5.3i abs system. My sensors have been cleaned and I have checked the front two for resistance and gap. Light comes on after short drive. Quote Link to comment Share on other sites More sharing options...
Cougar Posted October 18, 2004 Share Posted October 18, 2004 I think you need a scanner for OBD2 to do that. Quote Link to comment Share on other sites More sharing options...
edjackie88 Posted October 18, 2004 Author Share Posted October 18, 2004 I think you need a scanner for OBD2 to do that. My obdII code reader sez no trouble codes. I have heard there is a plug I hook a wire to and read the abs light blinks. Thanks for the thought. Ed Quote Link to comment Share on other sites More sharing options...
edjackie88 Posted October 21, 2004 Author Share Posted October 21, 2004 My obdII code reader sez no trouble codes. I have heard there is a plug I hook a wire to and read the abs light blinks. Thanks for the thought. Ed There is a black six pin plug above the accelerator pedal with two small black wire probes tape to it. You turn the key off, insert a probe in pin 6 (ushaped plug, lower right hole when u is up), turn the key on, count the long and short flashes. Look up the code. Mine was a 56 abonormal voltage output from G sensor. Thanks to Rod a Lithia Subaru, Oregon City, Parts. Ed Quote Link to comment Share on other sites More sharing options...
Cougar Posted October 21, 2004 Share Posted October 21, 2004 Thanks for the info about the procedure Ed. Quote Link to comment Share on other sites More sharing options...
