October 25, 200421 yr Suspend your desire to fix a problem, ignore WHY I might want to know this: Does anybody have a good feel (or hard doc/experience) with how long the wastegate clapper can stay off of its seat before something burns or otherwise gets damaged? As in, if you ran a turbo at its gated-boost limit, how long before its wastegate was damaged? How long before damage if wastegate was open at low-power settings (an otherwise non-positive manifold-pressure situation)? Thanks in advance!
October 25, 200421 yr IF YOU RUN IT OPEN, BYPASS MODE, you will have low to no boost IF YOU RUN IT CLOSED, NORMAL MODE, you run the risk of over-boost
October 25, 200421 yr it shouldn't bother it.. after all it never see's the same temps a a exhaust valve see's but like lots of things i could be way far wrong...go figure
October 25, 200421 yr Author IF YOU RUN IT OPEN, BYPASS MODE, you will have low to no boost IF YOU RUN IT CLOSED, NORMAL MODE, you run the risk of over-boost Please reread first line of my post. I have no intention of running the turbo outside of its boost range. I have some turbo experience dating back to the '70s (back when I had to deal with flow maps to find which $1000 unit best suited my application), and am not likely to do anything truly stupid.
October 26, 200421 yr so what your saying is my reply is not good enoughf or you huh... you have to bump it and get more ??? shesh...
October 26, 200421 yr Theoretically, at lower power levels, the wategate flapper could be off of its seat indefinately without damage. Also, I think, theoretically, if the engine was under heavy load, and the exhaust gas temp was very high, an unseated flapper could get red hot in a matter of seconds. depending on what it was made of would determine whether or not it was damaged.
October 26, 200421 yr Author Theoretically, at lower power levels, the wategate flapper could be off of its seat indefinately without damage. Also, I think, theoretically, if the engine was under heavy load, and the exhaust gas temp was very high, an unseated flapper could get red hot in a matter of seconds. depending on what it was made of would determine whether or not it was damaged. I understand both of your points. The real answer to my question lies, I think, in the original design and application specs for the turbo. It had to be able to withstand SOME period of time with wastegate clapper off of its seat, and from what I have heard (I don't have a boost gauge or anything else on my car that would tell me), the EA82T can run enough boost to keep the wastegate open. SOoo, sounds like Subaru either knew it was OK or just ignored it.
October 26, 200421 yr ok teh way that i know that these things work is when you start to get near the max boost psi the springs in the wastegates have is they start to "crack" open so you boost slows down a bit before it reaches max psi a mbc over comes that in ways but you still suffer from that before max psi wastegate cracking psi problem either way the system is stil partially open just before the max psi is achieved now going to electronic boost controll well thats diffrent as the electronics keep the waste gate closed totally until the set psi is reached then open it all at once and after wards usually pulse the duty solenoid on and off to keep the wastegate can at the max boost you want now since with electronic boost control keeping thewastegate closed up until the set psi the result is a car that has a faster boost responce <no sorta open wastegate> its more precise once it hits max psi and usually alot more responsive since the wastegate has no affet until the setpoint is reached on the other side the smaller waste gate cans have weak springs alot of the times so just the shear exhaust pressure can force the wastegate off its seat one of the reasons i wil be swapping my saab wastegate can onto the suby turbo its a bigger can bigger spring but ahh there is a catch its opening psi is 5lbs but thats parts of the good side since i runs a saab apc it measn until the apc hits the boost i want it will deny the wastegate signal to the can but on the otehr side if the apc picks up any problems it ca also drop the boost as far as 5psi anyways enough of my insane rambling
October 26, 200421 yr Author Oh, oddcomp, I guess I ignored you again, sorry... i was too busy washing my hair... or was it watching the grass grow... wasn't watching the paint dry, 'cuz its too wet to paint... I now how you can help me: give me a turbo and I will see how long it takes to burn the wastegate! lol
October 26, 200421 yr ah dam well see your s.o.l i have one thats sorta useabkle as a emergency spare and the other well.. unless you consider a half inch of in and out lay on the shaft god.. then well no spare turbo's for you oh wait i do have a saab 9k turbo i gott a rebuild one of these days and i have the turbo off a buick grand national that was carbed that needs a reuild as welll
October 26, 200421 yr Author ah dam well see your s.o.l i have one thats sorta useabkle as a emergency spare and the other well.. unless you consider a half inch of in and out lay on the shaft god.. then well no spare turbo's for you oh wait i do have a saab 9k turbo i gott a rebuild one of these days and i have the turbo off a buick grand national that was carbed that needs a reuild as welll Hey, I don't need it to produce any boost, just "sit there and take it". Too much work to change one out, even more work to drive down and see your sorry face . I can't believe that with all of these folk pushing the limit on their turbo's boost that they haven't an opinion on wastegate longevity. I guess they want it closed, not open! Oddcomp, PM'ing you
October 26, 200421 yr welll.. hell nice and tight wastegates.. makes for faster boost and more fun loose sloppy wastegates are no fun ..
