October 29, 200421 yr I disconnected the battery and when I re-connected the headlights flash even with the lights and ignition off. Is there some electrical reset switch?
October 29, 200421 yr I disconnected the battery and when I re-connected the headlights flash even with the lights and ignition off. Is there some electrical reset switch? Look under the dash on the driver's side, there should be a button you need to push to reset the alarm/keyless entry system.
