aftermarket source for disc conversion?
i have done a disc coversion with baccaruda before ,we used good "used parts with rotors turned and such.however i was searching for an alternative to that.i would like to find an oem setup from someplace other than the dealer.has anyone found this and if so,will you share ?i realize it could be pretty spendy.thanks
Easy, buy the rotor and caliper set from Shuck's or other parts store for a '88 turbo GL wagon. Use that with a junkyard hub and backing plate and you're good to go. You're not likely to find a hub and backing plate new from anyone other than a dealer although you can ask.
