Douglas Eck Posted November 1, 2004 Share Posted November 1, 2004 I've got a 98 Legacy that makes noise and feels a bit bumpy when I turn corners. The noise comes from the rear. It seems like it's coming from the rear driver's side, but that could be because I'm hearing it from the driver's side. The guy at my local garage (who I trust, but who is not a Subaru expert) says it's a bad rear differential. He also said that I should have it replaced at the dealer because it's not an easy repair. Does this seem reasonable? Are there any easy ways to verify a that a rear diff is indeed bad? Thanks, Doug Link to comment Share on other sites More sharing options...
mtsmiths Posted November 1, 2004 Share Posted November 1, 2004 Doug, it's more likely torque bind. Check tires for size conformity, equal pressure, and even wear. Search the BB, ther's LOTS of info on the symptoms around here. Link to comment Share on other sites More sharing options...
krusho Posted November 2, 2004 Share Posted November 2, 2004 Hi. I am brand new here and I am having the EXACT same problem with my '98 legacy. I've had both front axels replaced thinking it was the CV joints. :-\ What is torque bind????? Thanks, K Link to comment Share on other sites More sharing options...
friendly_jacek Posted November 3, 2004 Share Posted November 3, 2004 did you do a search? Link to comment Share on other sites More sharing options...
Douglas Eck Posted November 9, 2004 Author Share Posted November 9, 2004 I took it to a subaru dealer and they said the rear differential is fine but that the real transfer clutch and solenoid are bad. But I think I'lll get a second opinion. Does this sound reasonable for a 98 with 125,000*KM*? Doug (original poster) Link to comment Share on other sites More sharing options...
chadwick Posted November 10, 2004 Share Posted November 10, 2004 Hi. I am brand new here and I am having the EXACT same problem with my '98 legacy. I've had both front axels replaced thinking it was the CV joints. :-\ What is torque bind????? Thanks, K torque bind is your tranfer clutches for your awd, they bind when you turn it feels like the whole car is jittering and shaking. they are in the back of your transmission they need to be replaced could be costly depending on the dealer. the dealership i work at the repair is about $900 or so, it won't go away, once they start to bind they are pretty much shot Link to comment Share on other sites More sharing options...
J_h152 Posted November 24, 2004 Share Posted November 24, 2004 I got a 98 OBW and there is a howling noise coming from the rear end. I took it my mechanic and he said it a problem in the rear differential. I live in San Jose California and wanted to know if anyone out there knew of a good repair place that wont screw me like the dealership. I took my car to Stevens Creek Subaru and got raped when head gasket went out. Link to comment Share on other sites More sharing options...
cookie Posted November 24, 2004 Share Posted November 24, 2004 there is an independent Subaru place in Palo Alto that is supposed to be good. Sorry I don't know the name. Link to comment Share on other sites More sharing options...
