November 4, 200421 yr Can you put chains on an AWD Subaru? If so would you put them on the front? I got a pair for cheap at a yard sale and just wondering if I ever needed them if I would hurt the car by using them?
November 4, 200421 yr I’ve got a set (all 4 tire) of cable chains that I’ve run on my 99 Outback. I bought them when I lived in Boulder CO, and never got a chance to use them out there. I have used them a few times here in NY. Once I used them to pull someone out of a snow bank. They worked great. I pulled out a Chevy Lumina that was hung up on a huge snow drift and the front of the car was buried in a snow bank. I tried pulling the Lumina out with just snow tires but nothing, just spinning. It only takes a few minutes to put on the chains (but somehow seems much longer when you’re crawling around in the snow). I strapped on the tire chains and pulled the car out with ease and never spun a tire (I sure wish I had a hi-lo range though). There isn’t a ton of clearance in the wheel-wells so make sure your chains are tight. Cable chains have a low profile and work great but I don’t have any experience with any other types of chains. If they are loose you can do some serious damage so make sure you get them tight. If you put them on as tight as you can and drive a few feet you can usually re-tighten them a notch as they straighten themselves out on the tires. They are loud and I wouldn’t go over 30. Have fun in the mountains.
November 4, 200421 yr Author I’ve got a set (all 4 tire) of cable chains that I’ve run on my 99 Outback. I bought them when I lived in Boulder CO, and never got a chance to use them out there. I have used them a few times here in NY. Once I used them to pull someone out of a snow bank. They worked great. I pulled out a Chevy Lumina that was hung up on a huge snow drift and the front of the car was buried in a snow bank. I tried pulling the Lumina out with just snow tires but nothing, just spinning. It only takes a few minutes to put on the chains (but somehow seems much longer when you’re crawling around in the snow). I strapped on the tire chains and pulled the car out with ease and never spun a tire (I sure wish I had a hi-lo range though). There isn’t a ton of clearance in the wheel-wells so make sure your chains are tight. Cable chains have a low profile and work great but I don’t have any experience with any other types of chains. If they are loose you can do some serious damage so make sure you get them tight. If you put them on as tight as you can and drive a few feet you can usually re-tighten them a notch as they straighten themselves out on the tires. They are loud and I wouldn’t go over 30. Have fun in the mountains. Thanks for the info! I just looked at the chains I got are pretty trashed. I saw some at Costco last night for $35 so might just grab a new set. I have also seen those cable type, might look into those also. Thanks
November 5, 200421 yr Being a new Soobie owner, I now have the 10amp fuse in with my spare tire, in case (of a flat) I need to get to a tire shop. I also have one set of chains, which if needed this year, I will run on the front tires. This shouldn't pose a problem to the AWD gearing, should it? I have about 20% left on the tires that came with this 93' Leg. Wagon and I want to wait until next year for new tires. Any of you experts want to let me know if I need 2 sets of chains?? Kowboy PS: My wife thinks I'm a little crazy, but I really like the information on this board. Thanks!
November 5, 200421 yr Be very cautious with chains on the outbacks as the strut spring cones are very close. I think subaru discourages chain use. YMMV
November 5, 200421 yr I think you only have to worry if you change the geometry of the wheel or the chains are too big and hit the strut. Try the cables. They are low profile.
November 5, 200421 yr The handbook says chains go on the front only! Also, the recommended speed is very low, I can't remember it exactly, but it's less than 30mph!
