November 5, 200421 yr HAVE 88 GL 4WD WAGON and have just fitted an Hitachi air conditioner from another Subi. Had to fit the wiring loom too, but I didn't take the loom off the other Subi and I'm having trouble with wiring. I think I need to get a connection to the push button air con. switch on the dash but since its part of the existing loom I can't see where or how it connects and it would help if I had a wiring diagram. I know some one out there knows. I think under the bonnett is wired ok.although im not sure about looping in the radiator fan to work on the thermal switch and the a/c. I have a gregories manual but it has nothing on air con or its wiring. HELP HELP HELP!!!
November 5, 200421 yr Wally: The Haynes book has some basic schematics that should work for you. You can buy a copy for $15, or borrow it from the library. If that fails, I can mail you a photocopy. good luck, John thealleyboy@yahoo.com
