[HTi]Johnson Posted November 19, 2004 Share Posted November 19, 2004 Hey all. I am almost done with my 3AT to 4spd D/R swap. Just one problem. Where/how do I mount the 4wd lever, and are the "L" arms that go from the lever to the end piece on the transmission different between S/R and D/R? Quote Link to comment Share on other sites More sharing options...
1bignose Posted November 19, 2004 Share Posted November 19, 2004 if you got the bracked for the 4wd lever. when i did the swope i put it in 2wd set the lever down where i wanted it. then put i put the bracked on the lever. if you look on the bracked there is 2 holes set those holes next to the driver seat drill the hole and put nut and bolts in you will have to get under the car and might take 2 people to do let me know if it help Quote Link to comment Share on other sites More sharing options...
