December 2, 200421 yr hi can someone tell me please how to connet the 2 pipes ,2 lines that come from the automatic transmision to the radiator(oil cooler), in all the subaru with automatic transmision there is in the radiator, a part of the radiator is an oil cooler for the gear, it has 2 pipes that go to the gear, how do i connect them?up on the radiator to up on the gear , or up on the radiator to down on the gear. i'm stuck with 2 pipes that i don't know how to connect them. please someone can look under the hood in his car and tell me, i dont know how to connect it. is it matter anyway? thank you for your fast answer. in haynes it doesnt say anything about it. thank you all. moshe.
December 2, 200421 yr are you asking if it matters which hose goes on which pipe? it doesnt matter, you just hook them up =]
December 2, 200421 yr exactly. There is no particular way the ATF flows thru the rad cooler that I know of.
December 3, 200421 yr Author It Does'nt Matter For Shour? Can I Connect It Where Ever I Want ? Thank You Moshe.
December 3, 200421 yr thats right, just go ahead and plug them on and it'll work. Like the other guys said, it doesn't matter which direction the ATF flows through the radiator.
