EA81 auto/manual driveshaft: different?
An old post on converting ea81ts to manual say that the driveshaft must be replaced. I have done this, but they appear identical and the driveshaft from the auto is in much better condition. I would therefore like to swap the two. Am I missing some subtle, yet important, difference?
The same post also said the speedo cable must be replaced, but I am using the auto cable without problem.
Measure the distance between the u-joints, if they are the same then the driveline is probably the same.
Um I had a ea81 3 AT and did a swap to a manual. Using the same driveline.
[HTi]Johnson
____
edit
____
Oh, I'm not sure about turbo, they should be the same. But That's just what I think shoudl be right :brow: So yuo did a swap from Auto to manual?
