diff
my diff in me 85 gl 4wd d/r looks like it has a locked diff in the rear when i turn on the drive way i can hear it jumping on the innner wheel that i am turning i put one side on the jack and put it in 4wd and i could only turn the wheel a few inches then it would start driving the other side, so do these have locked diff
Jack the entire rear end off the ground and then spin the wheel. If the opposite side spins the same direction it is a limited slip. If it spins the other way it is open.
yep i no about the jack the entire rear off the ground and if the opposite wheel spins its lsd ill check the tag now
k i checked the tag didnt say lsd on the tag the gear ratio was 3.9 so im guessing it is a lsd, i just dont think it is tho because ive never seen a lsd work like that my bro has a ford with lsd in the rear and it doesnt do that the diff in the suby is working more like a diff lock
you should go back and read Qman's post more closely.
You have an open rear diff but a locked center diff
this is what is causing the jumping,
NOT the rear diff.
You brothers truck no doubt has an open center differential.
NOT the rear diff.
o ok thanks for clearing that up:)
i also lifted the rear up and yea the other wheel spun the opposite way to wat i was spinnning the other way, thanks guys yet again:)
