January 9, 200521 yr Hi, I wanting to swap my ea81 box for ea82 fulltime 4WD. FYI: I now have a ea82 turbo motor. I have found a Fulltime 4WD box from a non-turbo Leone. Will this gearbox be strong enough? I pretty sure it should be OK, but I don't really know. Also, I think think that spine counts are different. Is this correct? Is it possible to use a ea82 inner CV on the existing ea81 axles to make the gearbox work? Another small question. Are all Fulltime 4WD gearboxs LSD? Cheers for your help Hayden
January 9, 200521 yr Hayden here is a link that will be of some help http://www.ultimatesubaru.org/forum/article.php?a=53 I am moving this to the retrofitting section some good reading there
January 11, 200521 yr im not good at tying all the words together, with what i know. i need to see them all in front of me to understand.... i want an xt6 5 speed tranny in my hatchback... which axles, or a combination of axles could i use to accomplish this?
January 13, 200521 yr Author I have: Leone FT4WD 5 speed tranny with 25 spine count 1982 Leone 2WD/4WD car with 23 spine count How can I fit this tranny in this car?
