January 24, 200521 yr I'm having trouble removing these torx bolts from the head (see link below). Are they supposed to come out? If I put a breaker bar on them, they barely turn, and I'm afraid they're going to break if I apply any more pressure. http://www.teamyeti.com/bin/misc/exhaust1.jpg Thanks, Carmen
January 24, 200521 yr I'm having trouble removing these torx bolts from the head (see link below). Are they supposed to come out? If I put a breaker bar on them, they barely turn, and I'm afraid they're going to break if I apply any more pressure. http://www.teamyeti.com/bin/misc/exhaust1.jpg Thanks, Carmen they do come out, but I've broken more than have come out cleanly.... usually the torx head is so rusted I have to use a wrench on the outside.... lot's of PB Blaster or Yield, and let it soak..... heat also will help..... If I already have them on, I usually will leave them on, then (if the normal exhaust stud holes are stripped out, I just tap new threads into the metal spacers....
January 24, 200521 yr Author Did you put lots of PB Blaster for a few hrs? If not try it... The head is brand new, so I didn't think rust/corrosion would be an issue. I'll wrench at it some more. And yes, I stripped one of the exhaust studs. Oops.
