ea81 flywheel bolts
does anyone know what size bolts are used on the ea81 flywheel? I need to know diameter , legth, and pitch
thank you :]
dont know the length or dia without looking it up, but i DO know the thread is 1.00 instead of the 1.25 found everywhere else.
the stock bolts have a 14mm head but the aftermarket bolts generally have a 17mm head.
as far as the length goes they will be the same length as the ea82 flywheel bolt.
maybe m8 for diameter but dont quote me on that, but 14mm bolts on ea82 are m10
the stock bolts are M10x1mm and 30mm long grade 12 hardness 14mm heads with integral washers but that's for ea82..I'm not sure if ea81 is the same I think it is but not sure..
  • 3 months later...
thank you :]
The EA81 is 9mm from what I can tell and 1mm pitch. They are oddball.
