BobBrumby Posted February 3, 2005 Share Posted February 3, 2005 I wont int. wipper on my brumby that does not have them. I had a look under there this arvo and found a 6 pin plug conector that has one yellow wire jumpered back onto the connector, this look like it came this way from the factory as its a propper clear plastic plug. Would this be where the 6 pin int. wipper module plugs? It only occured to me while I was writing this to check the gender of the plug but forgot to and its night now. Also do you have to remove the console peice where the radio is to be able to acsess the shroud where the wiper switch is? Because i removed all the screws but it was stuck and i ran out of time. Link to comment Share on other sites More sharing options...
