problems with carb? still
ok so i found a leaking intake manifold gasket. i replaced and the problem got a little better. i have replaced both fuel filters, checked all vacume lines the vacume advance unit on the disty put ngk v power plugs in (noticeable differance) but still have a hesitation in my carb could this be from a disty a tooth off. i bought the car for 300 bucks all that was wrong was a bad pickup coil so i replaced the disty and thought at the time that i could have gotten it a tooth off but it ran so didn't think any more about it but now looking back i'm having second thoughts any help would be appreciated i'm trying to make it to moab with everone else
my check mark goes beside
the carb's accelerator pump is not squirting enough petrol.
try a can of Seafoam (NAPA, Advanced Auto et al) in the gas tank,
- it may be a semi clogged passageway.
Note this may take 100 miles of driving to work out the problem.
88 hatch w/EA81??
88 3 door w/EA82??
look on top of the lump near the front lip for engine ID
