Gravityman Posted February 8, 2005 Share Posted February 8, 2005 What is the differance between the EA82 and EA82T heads. I need to know so I can modify my XT6 heads for turbo application if the modification can be done. Does anyone have pics of both so I can see the differance side-by-side? Link to comment Share on other sites More sharing options...
Skip Posted February 8, 2005 Share Posted February 8, 2005 Scott, I believe you think there is some difference in the combustion chamber volume/shape. This is not the case and the comp. ratio is set by the piston crown.. The heads in question are identical except for a water and an oil port which the turbo unit has. Link to comment Share on other sites More sharing options...
