February 11, 200521 yr 84 sedan 4x4 with a auto trans,...there is a sound from the belhousing area when its cold, its kind of a knocking sound that happens intermintantly, the tach jumps when it knocks and there is good amonut of powerloss, however when the car warms up it runs fine and there is no noise and powerloss, and the tach works fine, its got me stumpped, i thought about the flexplate because i can stick a prybar in the timing hole and move it forward and back, so any ideas? thanks dusty
February 11, 200521 yr symptoms point to bad bushings in the distributor see if the shaft wobbles connection to knocking? maybe the drive gear is knackered and it locking up flex plate flex?
February 11, 200521 yr Author Well I can move it fore and aft with a pry bar, almost as if it was loose, I havebt checked the disty, that would explane the tach symptoms and the power loss and misfires
