OK. So I got a problem. Not real big, but not sure what it is.
The new Loyale is spiking up to hot and then going back down and running normal. It spikes after about 5 minutes of driving, but then comes back down. Also, it starts hard, and I can smell gas. It seems to idle a bit rough too. Are these all connected? Is it some kind of bad sensor? I don't know these things and some of you guys are suby genuises. :grin:
Let me know.
When the temp goes down does it stay down? It might be a thermostat. You could put a lower temp thermastat in.
The fuel smell might be a leaking fuel line? or ?
The cooling prob sounds very much like a sticking thermostat, try replacing it. As for the other probs, i'd check the ignition system (coil, leads, plugs etc) before looking at anything else.
Sticking thermostat. Also probably needs a tune up but first I'd check for any small fuel leaks then pull the DTCs.
