A/C HP draw?
How much Horsepower will an air conditioner compressor pump draw on on an XT6. Does any one know? Also how big of an electric motor do you think it will take to spin the compressor at optimal speed? This question leads up to an awsome experiment, I will be trying later!
MORE POWER!!!
i fabricated a mounting bracket to bypass my A/C for most of the year using a smaller belt which i'm running right now (being winter and all). i attached a picture. there is actually a one size shorter (like 20 or 40 mm shorter) 6 rib belt that may fit without using any bracket at all. but mine works fine like it is, so i'm not going to try the shorter belt until this belt is ready to be replaced.
i couldn't resize the picture to post here, so here it is:
http://www.xt6.net/forum/viewtopic.php?t=3772
compare the a/c compressor diameter to the crank pulley diameter to get an idea of what RPM range you need to run. the crank and a/c pulley are fairly close in size, so looks like the a/c typically runs 500 - 7,000 RPM's, easily doable with an electric motor. just might draw a!!loads of amps.
