February 27, 200521 yr Hello again, Taking the advice from previous inqury http://www.ultimatesubaru.org/forum/showthread.php?t=30681 on how to deal with rusty bolts, I've got left threaded drill bits as well as extractors (having quite many rusty bolts, I've decided it might be a wise investement) -Irwin Hanson set. So now I will be able to get them off I believe but I need to get ready -- find bolts to substitute the bad ones I will take off. Can anybody advise me on the size of such on Legacy 1995 AT Wagon? May be parts numbers and I would be able to find using google...? Thank you in advance
February 27, 200521 yr I'm not sure of the bolt thread & pitch size, but I'm sure you could call your local dealership and they could help you out.
February 28, 200521 yr The bolt size is 6mm(dia) x 1.0 mm(pitch)x 10mm (long) As far as where to buy them i would suggest the dealer, since they coudd get the right ones for that application SEA#3
February 28, 200521 yr Author The bolt size is 6mm(dia) x 1.0 mm(pitch)x 10mm (long)As far as where to buy them i would suggest the dealer, since they coudd get the right ones for that application SEA#3 Thank you a lot for the information!
