Friends Subaru problem
Hello, I do not own a Subaru as my screenname shows but my friends 1990 Subaru Legacy 2WD is in trouble. He told me when he put it in gear he heard a loud CLUNK and it would not move but the speedo would go up. I am not too familiar with Subarus so I found this and am turning to you guys for assistance. Thanx for all your help!
Hmmm,
I would venture to say that if the speedometer is moving then some parts in the A/T are working, but other parts aren't.
My conclusion would be that this is not good. Maybe he can find a good tranny in a junk yard.
Check to see if he wasted an axle.
Torque converter? Has he checked his tranny fluid level lately?
hopefully fluids not light grey(bad)/red(good)
couldn't he have popped a cv joint too.
Yep, I would say check the axel also. Before I bought my subie, my old sentra had the same problem. I would put it in drive, and only here clunking. Initially I thought is was a tranny problem, and since my car was an old piece of crap, I decided to sell it for $100 instead of fix the tranny. It turned out to be a broxen axel, but too late, I already sold it. Anyways, can't complain, love my subie but the wallet's hurting!
i was under the impression that the speedo was driven off one of the other more internal shafts of the tranny if not the pinion it self...
but it is possilbe i am just confused..
if i am not then would it not suggest at least a bunch of teeth have decided to relocate from either the ring gear or the pinion gear
but he did say clunk and not crunch/grind type noise
so i will go on the assumption i am confused and tired :)
