March 8, 200521 yr I have seen this somewhere on USMB, but for the life of me I can't find it again. I have searched "jet" "jets" "jet sizes" "weber jet's" etc etc If someone can give me the jet sizes required for a 32/36 weber on MY81 Wagon ( I think there was 3 sizes, Main/Air/Idle?) I would be very gratefull.
March 9, 200521 yr There is not a "one size fits all" answer. It varies depending on engine size, engine tune, ignition timing, the aircleaner you use, altitude, relative humidity, and perhaps a couple other variables that escape me. Assuming a stock engine and ignition timing, you can start with the following: Main Idle AC Pri 140 60 175 Sec 140 55 170 This is only a rough baseline to get your car started and idling. You WILL need to tune further to get the best driveability. Good luck and have fun! Regards
March 9, 200521 yr almost everything you want to know and more..........http://www.ultimatesubaru.org/forum/showthread.php?t=29778 Tim
