March 14, 200521 yr subarutheless's brat drivers side front end is messed up.. axle and hub/rotor are stripped, wheel bearing is toast. Will EA82 parts interchange with the brat? N/a of course. I was thinking using the EA82 spindle/hub/wheelbearing dealy bobber on the brat. with the ea81 axle. will this work? need fast answer, its gettin dark.
March 14, 200521 yr the only problem i can see having would be the fact of the caliper mount not being the same
