sam45 Posted August 31, 2003 Share Posted August 31, 2003 Hi! I am planning to change the coolant on my 96 Legacy Wagon 2.2. As per the user manual, all that's needed to drain the coolant is to open the drain plug at the bottom and also the air vent on top of the radiator. It does not say anything about the engine block drain plugs. However, the Haynes procedure includes this as one of the steps to drain the coolant from the engine. It looks like you need a special tool to open these plugs. I am hesitant to touch these plugs (in case of future leaks etc.) Can we get a decent job done without opening the engine drain plugs? Any help is greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted August 31, 2003 Share Posted August 31, 2003 I highly recommend a T fitting that you connect a garden hose to. When you take out the thermostat you get a positive flush. Quote Link to comment Share on other sites More sharing options...
