1993 Impreza check engine light
I'm trying to get the codes to blink on a 1993 Impreza I just purchased. All of the references I have found describing the terminal(s) I am looking for don't describe what I am finding. The only connector I find is pictured below. Can anyone give me a hand on this?
I've looked under the right side and see nothing! (All wires are connected). I am assuming that I am looking for a connector that is NOT connected to anything - correct????
Is there someone with this same vehicle that can post a very detailed description or post a photo (or tell me if I am indeed looking at the correct connector in the first photo I posted - AND tell me which terminals to connect/ground/??? to get it to flash codes and clear codes).
I've worked on a lot of cars through the years but this is getting frustrating (especially when the shop is asking $90 just to connect their tool and read the codes to me).
Norman
If I remember my 93 it was a flashing led right under steering turned on car and counted flashes most of the time found it to be egr. cleaned it and replaced 1 other part don't remember what and still check engine light was on had friend at garage check said most likely bad ECU advised to ignor sold 1 year later check engine light still on and off no problems driving
  • 1 month later...
Hi you guys.
Does anybody know how to read the CEL codes for a 93 Impreza with a 1.8L?
Thanks
