starkiller Posted April 22, 2005 Share Posted April 22, 2005 went to work and back today, no rattling!! so, on with the front crossbar first..will drive it a bit and see...then the rear one..then those mounting caps for each one of the rails...i WILL conquer this!! i hope... well, tried to tighten all of the screws in the rails and they were all real tight, so that's not the answer...if i went ahead and took them off, could i possibly add some kind of stuff under the rails to keep them quiet? also, if the screws are all tight, whats causing the racket? would turn up the stereo but dont have one Quote Link to comment Share on other sites More sharing options...
Ross Posted April 22, 2005 Share Posted April 22, 2005 Insulation tape!! Quote Link to comment Share on other sites More sharing options...
starkiller Posted April 22, 2005 Author Share Posted April 22, 2005 umm, explain please..i am not terribly bright... Quote Link to comment Share on other sites More sharing options...
Ross Posted April 22, 2005 Share Posted April 22, 2005 Well, if your lazy, you could just wrap the offending loose bits in insulation tape. If you want to fix it properly, then id go with your idea of puting some kind of packing in there. Quote Link to comment Share on other sites More sharing options...
starkiller Posted April 22, 2005 Author Share Posted April 22, 2005 that's the problem...nothing seems loose..well, screw wise anyway...since i havent takent them off yet maybe there is something underneath those rails that is ratttling... Quote Link to comment Share on other sites More sharing options...
operose Posted April 22, 2005 Share Posted April 22, 2005 if all the mounting hardware is tightened down enough, and it still rattles, I'd have to say that something is broken! there aren't any broken cross rails or anything that you noticed, are there? wiggle everything on it until you find the loose part. then apply 1/2 - 1 roll of duct tape or your favorite adhesive type product Quote Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted April 22, 2005 Share Posted April 22, 2005 I don't know about yours, but my '84 was missing some of the adjustable knobs and the sliding plate that they screw into was rattling around. When I'd come to a stop I could hear them slide to the front, then slide to the back when I started off. I just tightened the knobs I had all the way to the back and that kept them quiet till I found some more knobs. Quote Link to comment Share on other sites More sharing options...
starkiller Posted April 22, 2005 Author Share Posted April 22, 2005 nah, have all the knobs and plates and stuff...its a rattling sound, not a sliding type of sound..kinda like pinging...if ya bang your hand on top of the rails you can make the same sound it does whenever i go over 45.... Quote Link to comment Share on other sites More sharing options...
Handtool Posted April 22, 2005 Share Posted April 22, 2005 My guess is its the plastic end pieces on each rail vibrating against the roof. Pull them out and see if the noise stops. nah, have all the knobs and plates and stuff...its a rattling sound, not a sliding type of sound..kinda like pinging...if ya bang your hand on top of the rails you can make the same sound it does whenever i go over 45.... Quote Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted April 23, 2005 Share Posted April 23, 2005 Well, I thought I had all mine at 1st, but found some were missing. I believe there were 3 or 4 on each side. They would rattle also, just slid around under acceleration. Quote Link to comment Share on other sites More sharing options...
phishy75 Posted April 23, 2005 Share Posted April 23, 2005 could be the tracks on the roof itself have started to come off a bit. my '85 must have had lots of heavy loads put up top 'cause if you pushed on the roof, the metal sunk down, but the tracks would stay level. Never had any problems with vibrations, mind you you can't hear much when she's revving up around 6g's:brow: Quote Link to comment Share on other sites More sharing options...
starkiller Posted April 23, 2005 Author Share Posted April 23, 2005 well, took off the crossbars and any other loose bits...the outer rails are on by screws and the inner two by pop rivets...if you get down low and level with the roof and rails you can see where the rails are lifting from the roof with the rivets... so, if taking off all those bits doesnt help and it still rattles then i know those are the problem and i am sol, if the noise goes away, then i will put on one crossbar at a time and check for noise.. thanx everyone! alan Quote Link to comment Share on other sites More sharing options...
starkiller Posted April 23, 2005 Author Share Posted April 23, 2005 update..see first post! Quote Link to comment Share on other sites More sharing options...
