555Ron Posted April 25, 2005 Share Posted April 25, 2005 Is there anything special i should do to get the water out of my engine? I'm going to drain it out and put some new oil in tomorrow. I can't get seafoam here, but will this be enough of should i consider additives or do something special? Someone put water down the dipstick... Thanks in advance. Quote Link to comment Share on other sites More sharing options...
heep70 Posted April 25, 2005 Share Posted April 25, 2005 Drain the oil and put fresh oil in. Drive it around for an hour or two and that will evaporate the rest out. If you didn't drive it around the water should only be in the pan. Quote Link to comment Share on other sites More sharing options...
555Ron Posted April 25, 2005 Author Share Posted April 25, 2005 If you didn't drive it around the water should only be in the pan.Too late for that, but i haven't driven it too far... and i won't be until it gets changed. Quote Link to comment Share on other sites More sharing options...
heep70 Posted April 25, 2005 Share Posted April 25, 2005 Try some Marvel Mystry Oil along with the new oil. (8oz). That will help chase the water out of the lifters and bearings. You should be OK after that. Quote Link to comment Share on other sites More sharing options...
555Ron Posted April 25, 2005 Author Share Posted April 25, 2005 Try some Marvel Mystry Oil along with the new oil. (8oz). That will help chase the water out of the lifters and bearings. You should be OK after that.Ok, thanks for your help. I'll see what i can chase up. I might do a couple of oil changes and see if i can get that additive. Quote Link to comment Share on other sites More sharing options...
Snowman Posted April 25, 2005 Share Posted April 25, 2005 Someone put water down the dipstick... Ummm, okay. How did that happen? Quote Link to comment Share on other sites More sharing options...
555Ron Posted April 25, 2005 Author Share Posted April 25, 2005 Ummm, okay. How did that happen?I had the pressure cleaner to it to clean it up. I made sure the electrics didn't get wet... but didn't protect the dipstick. Quote Link to comment Share on other sites More sharing options...
