fuel mixture
How do I know if my brat is running to rich? I have heard that it blows a lot of petrol smoke when I floor it. It also doesn't need choke to start (I just use have to give it a few dabs of throttle.)
Its a EA81 twin weber carb setup btw.
The sound the intake makes when you give it WOT
(Wide Open Throttle)
is a dead give away.
If it gives a deep whoooooo but does not
accelerate like it should, indicates a rich condition.
A lean condition normally results in a backfire
through the carby.
Black soot on the sparking plugs will result also.
A cheap air fuel ratio gauge tied into the
02 sensor will also show you this.
