GlTurbo87 Posted April 30, 2005 Share Posted April 30, 2005 I have an 87 gl turbo 2 dr coupe. Yesterday, i was left work and noticed a puddle underneath. I didnt think that it was mine, because where i work, there are a lot of junk cars that park there. Today, i drove like i normally do, but i noticed the car was running unusually hot. When i got home, i checked under the hood, and the coolant tank was empty. I told my dad, and he filled the tank. When he checked under the car, there was coolant leaking underneath. We cant figure out where it is. There is coolant on my axle, and the crossmember behind the oil pan with 2 lines has coolant all over it. There is no sign of a leak on top of the engine, and it ran fine until this happend. We recently pulled the old engine out of it because when we bought it, the girl who previously owned it had put a hole in the top of the block. We imported a JDM engine, and put it in. Anyone have any ideas on what is wrong? any help will be greatly appriciated. Link to comment Share on other sites More sharing options...
erik litchy Posted April 30, 2005 Share Posted April 30, 2005 prabably want to start with the coolant hoses near the intake manifold? Link to comment Share on other sites More sharing options...
TROGDOR! Posted April 30, 2005 Share Posted April 30, 2005 More than likely it's the little silicon cooling hose running to the turbocharger. Them's a pain, good luck with it. Link to comment Share on other sites More sharing options...
86subaru Posted May 1, 2005 Share Posted May 1, 2005 i agree with trogdor , my 88 turbo full time 4wd a/t did the same thing , but also check heater hoses, if your going to change the coolant hose also change the oil hose which goes into a metal line , Link to comment Share on other sites More sharing options...
GlTurbo87 Posted May 1, 2005 Author Share Posted May 1, 2005 Thanks alot guys. I found out the problem. The hose runs underneath the compressor side of the turbo. It had a pretty good size hole in it...Enough to spray a good 5-10 feet if it it shot into the air. Gonna fix it tomarrow. Link to comment Share on other sites More sharing options...
TROGDOR! Posted May 1, 2005 Share Posted May 1, 2005 Make sure you use silicon hose. Link to comment Share on other sites More sharing options...
