94 GX 2.2. Touring Wagon Cruise Control
Does anybody have the right part nos and/or help on fitting a cruise control on the Legacy 94 Touring Wagon? Any suggestions very welcome.
Knijn2007
Are you looking to fix the stock one, or you want to install one since yours does not have it?
I don't know if subuaru makes a kit to install cruise or not. If they don't, it'd be rather difficult in my mind to try and piece all the individual parts and electrical stuff together to make the stock cruise work.
since my soob has no cruise i'm trying to find out if a stock solution is available or if a universal kit would be easier to install. The linkage for a throttle bowden-cable is already on my engine, so i would prefer one that links up that way. Since the soob's just had its distribution overhauled together wit some other parts that weren't up to mark i'd like to make it as complete as possible. The ride earned it after 278.000 K's!
Apparently from what Craig said, Subaru did make a kit to add cruise. I couldn't tell you whether the same kit is available in Holland, but it'd be worth asking your local subaru dealer if something similar is still available for your car.
Check with Folger Subaru. They seem to have cruise kits for all years of the Impreza, but don't list anything for the Legacy: http://www.flat4performance.com/closeout.htm
At least they might tell you the part number, although a knowledgeable dealer
anywhere should be able to do the same. You can then enter the part number on www.partsvoice.com to which many US dealer's inventories are linked, and there will a good chance someone will have it, even if at a "list" price.
