May 27, 200520 yr anyone know the size of the front and rear speakers in an 86 gl wagon? i am getting conflicting reports on line.
May 27, 200520 yr the fronts are 4'' and the raer door speakers are 6.5''....you might be able to put in 6'' x 9'' in the rear doors if there is enough clearance, osme speakers have bigger magnets than others, but as far as the fronts go,.....your stuck with 4''. ~Josh~
May 29, 200520 yr You can use 5 1/4 in the front if you use the plastic mount from a loyale with the bigger front speakers
