Temp sensor question
My 92 Loyale wagon seems to have an intermittant temp guage. Works fine most of the time, but now and then it just goes dead for a while. I know the coolant is topped off and everything is running fine. I think it might be the sensor. Is the sensor that runs the guage the one in the thermostat housing, that normally has a green connector on the wire pigtail?
Thanks
the coolant sensor with the green pigtail is for the computer. The sensor for the gauge in the dash is the one with a single plug.
I'd guess that the connection there is just corroded and needs to be cleaned. After that, you can start doing continuity tests on the wire to ground.
When it goes dead, I assume it goes to the cold end? If so, there must be problem in the dash itself, as if the sensor wire was grounded, it would go to the HOT end.
That's it. There are two others: the "coolant temp sensor" (which talks to the ECU) mounted directly into the intake manifold, and the "thermoswitch" on the radiator (which turns the radiator fan on and off).
