Power Steering Swap 2.5 to 2.2
If you do the 2.5 to 2.2 engine swap in an Outback or other newer Subaru, your power steering lines will not be supported by the normal brackets. You either have to make a support or switch the lines.
If you pull the lines from a 2.2, the fitting and the fitting off the pump, you can do the swap in about 45 minutes. Thats all you need and everything will bolt up.
